can i finally now get 2mb!!!
Have tried twice with plusnet to get 2mb as my attenuation etc are in range for 2mb, but both times have failed.
Noticed last night on my router that my available downstream speed has jumped up from something like 1118kbps to a DownStream Connection Speed of 2272 kbps .
Do you think this may finally mean I can get 2mb?
1 REPLY
Alecto
That says that you are synced at 2Mb.
So one of the regrades must have worked.
