bt speedtester results??
just noticed my speeds have dropped of today after messing about with the phone line yesterday putting a new line in upstairs.
so I've just done a test on speedtester.bt.com and I'm sure it used to say what the maxed speed was and not just profile speed? i'm I right?
Test1 comprises of Best Effort Test: -provides background information.
Assured Rate IP profile on your line is - 1500 kbps Actual IP throughput achieved during the test was - 942 kbps
If you wish to discuss these results please contact your ISP.
my router is giving down: 8128kbps and UP: 448kbps
Fixes: 41
It still does, i've just done one on my office line
IP profile for your line is - 7150 kbps
DSL connection rate: 832 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 3932 kbps
You are using http://www.speedtester.bt.com/ aren't you ?
James
Looks like you've been syncing at 1728Kbps. If you are now syncing at the full 8Mbps, you speeds should repick up again in the next 3 days.
thats fine, cheers James.
but why aren't I getting a full reading off bt speedtester?
James
Good point. I would have expected slightly higher. Do you notice any difference if you do a reboot and then try again?
was this aimed at me? cos it doesn't sound like it
anyway, BT profile is back up at 7150 now, how long will it take for plusnet to catch up, as this is still down at 2000?
This is now showing at 7mb, if you haven't reconnected since then you won't have picked up the new profile. All you need do is drop the connection for 5-10 minutes or so and then reconnect and things should improve dramatically.
Hope this helps, sorry for the hassle,
