bt and homecall
bt and homecall
i currently have a bt line and all calls are routed thru homecall. as from Dec1st homecall are taking over the line rental using the BT line socket, will this make any difference to plusnet. or is just the same as bt.
bt and homecall
It really depends on what BT do with the line. If they consider it a change of user or many other actions, normally all services (includeing ADSL) will be removed.
As moving your line rental is something new, you should really contact homecall and get them to confirm nothing will happen with your ADSL service when they take over the line rental.
If ADSL is removed by BT, you will have to pay a new activation fee to have ADSL enabled gain.
Plusnet have no involvement in this activity and could not confirm if ADSL will or will not be effected by this action.
bt and homecall
Homecall say it will make no difference to the way you use your line:
http://www.homecall.co.uk/recommend/linerental.asp
