browsing speeds
browsing speeds
hi folk's
anyone got any tips on speeding up my web browsing?
i used my brother inlaws pc with 1/2 meg blueyonder line and found the browsing much faster.
i've tried changing the mtu to 1458 & 1500 but neither seem to make a difference.
our download speeds are virtually the same so the conection is OK.
i've also tweaked with DR TCP from dsl reports ?
they show no faults on there tweak test
So what's the problem Huh??
any comments welcome
thanks
Mark
browsing speeds
This is related to the differance in peering arrangments.
You have to remember that +Net are not BlueYonder and ADSL is not cable.
They are both two differently connected technologies, with two different connection points to the internet.
You may weel see faster speeds to sites than your friend does.
browsing speeds
thanks for the reply
i just thoght maybe my pc was not configured correctly or there was some fine tuning that could be done to improve the browsing.
thanks anyway
mark
browsing speeds
I have found that changing your DNS server can speed up or slow down general browsing.
Bill
browsing speeds
Hi Bill,
Which DNS server ru using then?
browsing speeds
ditto
Bill
also how do you change it?
mark
browsing speeds
yeah, what DNS servers u using?
stonechat
DNS
I.m using 212.159.13.49 and212.159.13.50
I believe there were originally other DNS servers.
Bob
browsing speeds
These are the best DNS entries to use, there are others available but they are less reliable.
Chris
