bizarre pings again
mike001
bizarre pings again
Getting bad pings on lo0-plusnet.ptn-ag2.plus.net
looks ok on lo0-plusnet.ptn-ag3.plus.net
1 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms [192.168.0.22]
2 138 ms 132 ms 136 ms 155 ms 176 ms 126 ms 102 ms lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
3 138 ms 136 ms 130 ms 155 ms 151 ms 127 ms 100 ms ge1-0-0-204.ptn-gw1.plus.net [84.92.3.105]
4 139 ms 133 ms 129 ms 155 ms 151 ms 124 ms 97 ms gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 144 ms 138 ms 136 ms 164 ms 156 ms 130 ms 106 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 147 ms 136 ms 137 ms 163 ms 158 ms 130 ms 103 ms vl4.pri.ptb-gw3.plus.net [195.166.129.226]
7 149 ms 139 ms 138 ms 166 ms 159 ms 133 ms 104 ms ptb-games01-if1.games.plus.net [212.159.6.211]
anyone else getting this ?
bizarre pings again
been getting this all day, it's cos of peak period all of sunday. Plusnet don't realise they aren't doing a very good job off traffic shaping, pings are still terrible. Always are between 18:30 and 23:00.
mike001
bizarre pings again
one of the returned ticket reply about this problem was .....
Early to late evening on Sundays and Mondays are the busiest times on our network, therefore these are likely to show up the heaviest contended pipes.
I don't believe that there are any plans to load balance the pipes. Natural churn should take care of any balancing that may be needed.
and trying to play on the +net server is a no go with the pings to night......... :-(
lo0-plusnet.pth-ag3.plus.net
Target Name: ptb-games06-if1.games.plus.net
IP: 212.159.6.221
Date/Time: 01/08/2005 21:45:45
1 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms [192.168.0.22]
2 165 ms 194 ms 160 ms 144 ms 128 ms 145 ms 161 ms 139 ms 136 ms 173 ms 183 ms 176 ms 143 ms 148 ms 188 ms 174 ms 158 ms 187 ms 195 ms * lo0-plusnet.pth-ag3.plus.net [195.166.128.64]
3 163 ms 194 ms 156 ms 136 ms 129 ms 146 ms 160 ms 140 ms 137 ms 172 ms 183 ms 171 ms 144 ms 147 ms 179 ms 173 ms 154 ms 186 ms 194 ms * ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
4 163 ms 193 ms 162 ms 134 ms 128 ms 146 ms 160 ms 141 ms 138 ms 169 ms 181 ms 170 ms 142 ms 148 ms 179 ms 174 ms 152 ms 191 ms 193 ms * gi5-0-22.pth-gw2.plus.net [212.159.4.5]
5 171 ms 197 ms 160 ms 137 ms 134 ms 154 ms 164 ms 148 ms 147 ms 177 ms 186 ms 171 ms 147 ms 153 ms 184 ms 176 ms 159 ms 196 ms 199 ms * atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 172 ms 196 ms 159 ms 137 ms 134 ms 156 ms 164 ms 151 ms 148 ms 178 ms 185 ms 170 ms 151 ms 154 ms 183 ms 176 ms 161 ms 198 ms 199 ms * vl4.pri.ptb-gw3.plus.net [195.166.129.226]
7 176 ms 196 ms 158 ms 137 ms 134 ms 159 ms 165 ms 154 ms 150 ms 176 ms 187 ms 166 ms 151 ms 152 ms 182 ms 177 ms 161 ms 196 ms 196 ms * ptb-games06-if1.games.plus.net [212.159.6.221]
lo0-plusnet.pte-ag2.plus.net
Target Name: ptb-games01-if1.games.plus.net
IP: 212.159.6.211
Date/Time: 01/08/2005 21:42:57
1 1 ms 1 ms 0 ms 0 ms [192.168.0.22]
2 190 ms 167 ms 160 ms 159 ms lo0-plusnet.pte-ag2.plus.net [195.166.128.72]
3 163 ms 163 ms 156 ms 155 ms ge0-0-0-504.pte-gw1.plus.net [84.92.4.89]
4 169 ms 164 ms 155 ms 157 ms gi5-0-22.pth-gw2.plus.net [212.159.4.5]
5 167 ms 171 ms 158 ms 162 ms atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 168 ms 173 ms 158 ms 166 ms vl4.pri.ptb-gw3.plus.net [195.166.129.226]
7 168 ms 171 ms 159 ms 165 ms ptb-games01-if1.games.plus.net [212.159.6.211]
lo0-plusnet.ptn-ag1.plus.net
IP: 212.159.6.221
Date/Time: 01/08/2005 21:44:09
1 0 ms 1 ms 0 ms 0 ms 1 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms 0 ms [192.168.0.22]
2 175 ms 189 ms 183 ms 194 ms 180 ms 184 ms 207 ms 188 ms 164 ms 189 ms 192 ms * lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 * 188 ms 180 ms 192 ms 176 ms 186 ms 184 ms 192 ms 162 ms 176 ms 194 ms * ge0-0-0-103.ptn-gw1.plus.net [84.92.3.17]
4 * 188 ms 184 ms 192 ms 174 ms 183 ms 186 ms 189 ms 164 ms 175 ms 194 ms * gi4-0-23.pth-gw2.plus.net [212.159.4.21]
5 * * 191 ms 198 ms 178 ms 189 ms 191 ms 194 ms 168 ms 181 ms 198 ms * atm0-1-0.ptb-gw1.plus.net [195.166.129.246]
6 * * 194 ms 198 ms 175 ms 187 ms 193 ms 193 ms 166 ms 183 ms 196 ms * vl4.pri.ptb-gw3.plus.net [195.166.129.226]
7 * * 195 ms 198 ms 175 ms 186 ms 192 ms 194 ms 167 ms 183 ms 196 ms * ptb-games06-if1.games.plus.net [212.159.6.221] Cry
mike001
bizarre pings again
think you could be right ...my +net speeds tests are all over the place
01-08-2005 22:15:01 1363.9
01-08-2005 22:06:45 883.7
01-08-2005 22:03:37 652.9
01-08-2005 22:03:23 957.7
01-08-2005 22:03:09 1192.4
28-07-2005 23:18:44 1888.1
28-07-2005 23:17:53 1906
strange thing is I can still download at 1.82Mbps from +net newsgroups
mike001
bizarre pings again
Very strange my router logs show I was disconected at Mon, 8/01/2005 22:37:42
When it reconected the ping and speeds and pings are back to normal ??
.168.0.33 Mon, 8/01/2005 22:38:17
1|PPP : PPP Connection OK Mon, 8/01/2005 22:37:52
2|PPP : IPCP OK Mon, 8/01/2005 22:37:52
3|PPP : IPCP Start Mon, 8/01/2005 22:37:52
4|PPP : CHAP OK Mon, 8/01/2005 22:37:52
5|PPP : CHAP Recv Challenge Mon, 8/01/2005 22:37:51
6|PPP : CHAP Start Mon, 8/01/2005 22:37:51
7|PPP : LCP OK Mon, 8/01/2005 22:37:51
8|PPP : LCP Start Mon, 8/01/2005 22:37:49
9|PPP : PPP Start Mon, 8/01/2005 22:37:49
10|PPP : CHAP Recv Challenge Mon, 8/01/2005 22:37:48
11|PPP : CHAP Start Mon, 8/01/2005 22:37:48
12|PPP : LCP OK Mon, 8/01/2005 22:37:48
13|PPP : LCP Start Mon, 8/01/2005 22:37:48
14|PPP : PPP Start Mon, 8/01/2005 22:37:48
15|PPP : PPP Disconnect Mon, 8/01/2005 22:37:48
16|PPP : CHAP Start Mon, 8/01/2005 22:37:48
17|PPP : LCP OK Mon, 8/01/2005 22:37:48
18|PPP : LCP Start Mon, 8/01/2005 22:37:48
19|PPP : PPP Start Mon, 8/01/2005 22:37:48
20|PPP : PPP Disconnect Mon, 8/01/2005 22:37:46
21|PPP : LCP Start Mon, 8/01/2005 22:37:46
22|PPP : PPP Start Mon, 8/01/2005 22:37:46
23|PPP : PPP Disconnect Mon, 8/01/2005 22:37:44
24|PPP : LCP Start Mon, 8/01/2005 22:37:44
25|PPP : PPP Start Mon, 8/01/2005 22:37:44
26|PPP : PPP Disconnect Mon, 8/01/2005 22:37:42
