bittorrent
bittorrent
hey im downloading of bittorrent and the best i can get is about 4kb/s is this because i am behind a firewall if so how do i configure it to allow downloads? i use norton.
1 REPLY
Alecto
bittorrent
Have a look at this guide which should help you.
But if you're on Broadband Plus, then that is the problem and you will never get decent P2P speeds unless you upgrade to premier.
