binatone adsl500 no desktop icon
I have followed the instructions ok so far and finished inatalling the modem drivers, it says their should be an icon on my desktop (binatone adsl500) but it isnt their as an alternative it suggested to go here http://192.168.1.2 but it doesnt exist , so im not best happy as yet i cant even get to the stage where i put my username and password in , anyone got any suggestions ?Huh
1 REPLY
Does your modem get picked up as a new USB device. At this point shove your install CD and you should be click through Yes, Next etc from start to finish.
If you do this and no icon appears (also check in your Network Connections folder) you may have a problem. Check you have admin privilidges on your PC.
Tech support is very good so phone/log a ticket if you're still stuck/.
