bill paid but dl speeds r very slow
brettking24
Hi i have paid my monthly bill but my dl speeds are very slow still,i thought after each bill is paid that my dl speeds would go back to normal untill i reach the dl limit.
not happy at all with plusnet.
once my contract runs out im out of here!!!
a bit hasty arent you? im sure it will be easily solved.
run a speed test here http://www.speedtest.bbmax.co.uk/ and give the details in this thread, itll help the support team figure out your problem
brettking24
well....
well when im paying £22 a month i expect good service.
just done the test
dl speed is 5043kps
ul 265kps
when im dl using u torrent i get like 15 max at this moment in time
what contract are you on? also is it a public torrent? they are well known for sucking speed wise ;p
plus remember this is peak time now, most gold (p2p and other unimportant protocols) have a lot of packets dropped to make sure web browsing, email and all other more important services run quickly
edit: also another thing to check, make sure your ports arent being blocked by a firewall and are forwarded on your router (if you have one)
Basic rule of thumb, don't bother torrenting during peak hours, 6pm till midnight.
I find I'll typically get 10-40KBs during peak times, doesn't matter if it's private, public, well seeded etc. This then increases to 300-600KBs after 1am.
