big jump in speed result
vic_newey
Tried the Dr TCP tweak & set MTU 1478 and RWIN 17256, & had big jump in +net speedtest, usually around 470 it jumped to 495, 491, 501.1, 500.8, 492
average mid 900's
I have tried this tweak before with no result.
I have 2nd 80gig hardrive so I restarted with this & speedtest was around usual 470, so I was then sure it was the tweak & not because the other 49 who share my bandwidth had all gone on holiday! I altered the setting & yes, 495, 501, 492.
I have often noticed how ' the size of download for your connection' varies , sometimes less than 1 meg , often 1.64 meg, sometimes 2.4 meg, is this normal?
I got 2.94MB on a 512k connection - i woudn't worry about it
I've had 512.9 on a 512 connection a couple of times this week myself (if only :lol: ) try the ADSL Guide speed tester I think its more accurate than +nets.
