best Wireless ADSL Router With Built In Modem?
Hi i'm new to this forum and need some advice. I need some opinions on which is the best Wireless ADSL Router With Built In Modem, 'Netgear DG834GT Integrated ADSL Modem and 108Mbps 802.11g Wireless Firewall Router' or '3Com Wireless ADSL Router With Built In Modem And Free Wireless PC CARD 54mbps'?
My current setup up is :
Solwise Modem (brought with PlusNet)
Zonet 8 Port Ethernet Switch
XP with Nortons systemworks 2003.
Moderators note by John (johnessex) Topic moved to a more suitable part of the forums.
I have found the forums @
http://www.expansys.com/forumoverview.asp
To be good for hardware issues, and a great help, in choosing hardware.
Sounds like you have a short list, so just have a look, and see what issues other users are having.
Chilly
Cool many thanks for the reply and link. Cheesy
Personally, I use a Belkin F5D7630 and am very happy with it.
ADSL modem & router - includes 4 10/100 LAN ports, 802.11g (backwards compatible with 802.11b), firewall, DHCP/DNS server, MAC/IP filtering - very easy to setup and manage Smiley
Cheers
Michael
There are some reviews over at adslguide.
Hope this helps.
