bandwidth clarification....
Just wondering if someone can help me out on this.
I'm looking to up my connection from 1 to 2Mb's. Not sure which package to chose on the 2Mb line though. My bandwidth usage isn't extravagent, thus I was thinking of going for a 6gig capped service.
What if I was to exceed that, could I just change to the next level up or even unlimited without any penalty?
Cheers
Plusnet Staff
Plusnet Staff
You can upgrade at any time, so if you choose 6GB then you can easily switch to 7GB or the Premier option. The only cost being the price of the extra GB's (or difference to the Premier option).
thanks for your prompt reply Dave, Cheers.
