auto login
dekker
auto login
using xp home i have two profiles one each for my wife and i.
Auto login works fine for me but it will not work from my wife's profile.
After activating from her profile there is a login cookie stored in her folder similar to mine.
But login is still requested every time :?
auto login
What period did you select for the auto-login? Try 6 months. Anything over 1 year does not seem to work.
dekker
auto login
Thanks Peter, I set the period for 5years. However everything seems to be working OK now. Perhaps there were gremlins on the site this morning.
Or perhaps you have to do a reboot to make it work! Smiley
