assigned incorrect IP?
dragona
hi on several occasions now ive been assigned the wrong ip
the most recent one was a BT ip address : 81.152.42.33 while this was assigned i couldnt use my internet service at all is this a prob my end or just a minor bug in how you assign IP's?
1 REPLY
This is cause by BT engineering work at your local exchange or links to the nearest POP, too many failures to authenticate and a few other error conditions.
It is not caused by PlusNet assigning you the IP address.
Check the exchange checker HERE to see if there have been any recent works on your exchange (the checker doesn't include all works), which may explain it.
Further, log (time, date) the times this happens in future, and if needed, raise it as a fault to PlusNet.
