as-hosting.com
as-hosting.com
Can anyone access www.as-hosting.com?
This link was ok till yesterday now all i get is dns errors.
I know nothing is wrong with the server there as I have a website hosted and have been in contact with the owner.
[Moderators note (by Thomas): URL fixed for you.]
painswck
as-hosting.com
Sorry but no problem from here.
Cheers
Roland
phillight
as-hosting.com
nslookup www.as-hosting.com 212.159.6.9
Server: ptn-cdns01.plus.net
Address: 212.159.6.9
*** ptn-cdns01.plus.net can't find www.as-hosting.com:; Server failed
C:\Documents and Settings\Phil Light>nslookup www.as-hosting.com 212.159.13.49
Server: pth-cdns01.plus.net
Address: 212.159.13.49
Non-authoritative answer:
Address: 69.93.203.170
Aliases: www.as-hosting.com
Looks like one of the DNS servers is playing up. Try setting your server to 212.159.13.49 which appears to be working. There is another post somewhere about 6.9 failing on a few sites.
Phil
as-hosting.com
Was working for me the other day, aint now. Tho I wouldnt trust them, my current host was hosted on them, and the admin there sent an email to his host impersonating my hosts email asking for a format. So as-hosting screwed hundreds of sites over.
as-hosting.com
This is the second time in a few months people have had problems with as-hosting
see this thread from early last month
http://portal.plus.net/central/forums/viewtopic.php?t=16991
I can't access www.as-hosting.com either.
as-hosting.com
So this must be a plusnet fault?
As-hosting hasnt changed any configs yet it isnt working anymore.
In the meantime..I have had to add a few more dns servers so that i can access.
as-hosting.com
Not all the PlusNet DNS servers can resolve the IP address for www.as-hosting.com
C:\Documents and Settings\Peter>nslookup
Default Server: pth-cdns01.plus.net
> www.as-hosting.com
*** pth-cdns01.plus.net can't find www.as-hosting.com: Server failed
> server 212.159.13.50
Default Server: pth-cdns02.plus.net
Address: 212.159.13.50
> www.as-hosting.com
*** pth-cdns02.plus.net can't find www.as-hosting.com: Server failed
> server 212.159.6.9
Default Server: ptn-cdns01.plus.net
> www.aw-hosting.com
*** ptn-cdns01.plus.net can't find www.aw-hosting.com: Non-existent domain
> server 212.159.6.10
Default Server: ptn-cdns02.plus.net
Address: 212.159.6.10
> www.as-hosting.com
> server 212.159.11.150
Default Server: ns1.plus.net
Address: 212.159.11.150
> www.as-hosting.com
> server 212.159.13.150
Default Server: ns2.plus.net
Address: 212.159.13.150
> www.as-hosting.com
The result:
13.49 - server failed
13.50 - Non-existent domain
6.9 - server failed
6.10 - reply 69.93.203.170
11.150 - reply 69.93.203.170
13.150 - reply 69.93.203.170
So the default DNS servers and 6.9 don't have the domain listed but the rest do. This is a PlusNet issue - especially when the DNS server returned server failed. I have performed a DNS test on 13.49 & 13.50 and they are responding to lookups without any problems.
hatton920, I suggest you raise a ticket suggesting the DNS servers are out of step using the tests I did above.
as-hosting.com
Not necessarily, it could be a bad DNS that is propagating. PlusNet, and other ISP's, would pick up the bad DNS during normal DNS updates. The bad DNS record would come from as-hosting.
as-hosting.com
PlusNet still need to check - because until they do they will not know if it's a bad DNS record or a bad server config.
as-hosting.com
can't access either
as-hosting.com
peter:
my reply was to hatton920, I had to leave the PC for a while before finishing the reply. Your reply then beat mine. Shockedops:
Just to clear up any confusion.
as-hosting.com
OK Colin.
Here is another lookup with more details. The server error on .49 and .50 should not be happening. In this example, only 11.150 has an A (IP) record to return which is worse than the previous check and may indicate a bad DNS record being propagated.
1 www.as-hosting.com ALL Query sent to 212.159.13.49
1 11004 ERROR Name server failed
1 Lookup complete
2 www.as-hosting.com ALL Query sent to 212.159.13.50
2 11004 ERROR Name server failed
2 Lookup complete
3 www.as-hosting.com ALL Query sent to 212.159.6.9
3 www.as-hosting.com CNAME 12362 as-hosting.com
3 as-hosting.com NS 170762 ns1.as-hosting.com
3 as-hosting.com NS 170762 ns2.as-hosting.com
3 Lookup complete
4 www.as-hosting.com ALL Query sent to 212.159.6.10
4 www.as-hosting.com CNAME 11511 as-hosting.com
4 as-hosting.com NS 65124 ns1.as-hosting.com
4 as-hosting.com NS 65124 ns2.as-hosting.com
4 Lookup complete
5 www.as-hosting.com ALL Query sent to 212.159.11.150
5 www.as-hosting.com CNAME 14400 as-hosting.com
5 as-hosting.com NS 14400 ns2.as-hosting.com
5 as-hosting.com NS 14400 ns1.as-hosting.com
5 ns1.as-hosting.com A 108075 69.93.203.170
5 ns2.as-hosting.com A 108075 69.93.203.171
5 Lookup complete
6 www.as-hosting.com ALL Query sent to 212.159.13.150
6 www.as-hosting.com CNAME 14400 as-hosting.com
6 as-hosting.com NS 14400 ns2.as-hosting.com
6 as-hosting.com NS 14400 ns1.as-hosting.com
6 Lookup complete
as-hosting.com
Already have done a ticket yet plusnet are saying its my hosts errors.
Ps www.pcrepairs-upgrades.co.uk is one of my sites hosted by as-hosting.com
Dear Customer,
There must be a problem with the ISP / host showing the dns or the zone files must have jsut been updated as i have checked with two other ISPs DNS servers and only 1 out of 7 DNS servers have the correct information. I have attached my results below:
If the information has jsut been updated please allow 48 hours for DNS server to pick this information up.
Regards,
CCheesyocuments and SettingsAgent>nslookup www.pcrepairs-upgrades.co.uk 158.152.1.
58
Server: cache-1.ns.demon.net
Address: 158.152.1.58
DNS request timed out.
timeout was 2 seconds.
*** Request to cache-1.ns.demon.net timed-out
43
Server: cache-2.ns.demon.net
Address: 158.152.1.43
Aliases: www.pcrepairs-upgrades.co.uk
CCheesyocuments and SettingsAgent>nslookup www.pcrepairs-upgrades.co.uk 212.159.13
.50
*** pth-cdns02.plus.net can't find www.pcrepairs-upgrades.co.uk: Server failed
.49
*** pth-cdns01.plus.net can't find www.pcrepairs-upgrades.co.uk: Server failed
CCheesyocuments and SettingsAgent>nslookup www.pcrepairs-upgrades.co.uk 212.159.6.
10
*** ptn-cdns02.plus.net can't find www.pcrepairs-upgrades.co.uk: Server failed
CCheesyocuments and SettingsAgent>nslookup www.pcrepairs-upgrades.co.uk 193.252.19
.3
*** Can't find server name for address 193.252.19.3: Timed out
Server: UnKnown
Address: 193.252.19.3
*** Request to UnKnown timed-out
.4
*** Can't find server name for address 193.252.19.4: Timed out
Server: UnKnown
Address: 193.252.19.4
as-hosting.com
I have had sucess on all 6 name servers (2x telehouse east, 2x telehouse north, 2x authorative PlusNet server).
However, I attempted a lookup on the authorative servers for as-hosting.com. Both ns1.ashosting.com and ns1.as-hosting.com fail to respond.
I can get to the website, and considerign there website is supposed to be on the same IP as ns1.as-hosting.com, it would suggest that somthing is wrong there side.
Based on the number of reports I am seeing lately about them, they do not seem the best host to be choosing right now.
