anyway to get draytek vigor 2500 to use 2 static public ips?
Can anyone tell me if its possible to route 2 static IP's through a dreaytek vigor 2500
There does not seem to be anyway, and it seems NAT is the only option with 1 IP fixed.
If anyone has any ideas or a cheap router which will handle 2 or more fixed IP's Please let me know
Cheers
James / xyleneuk
one to one NAT routers are usually quite expensive - linksys make a few routers that will allow you to setup one to one nats -
The RV range of routers allow for this
http://www.linksys.com
I don't know the answer, but it might be worth having a look on the Draytek support forums. If the 2500 is just an older version of the 2600 (which I have) then I suspect it is possible.
--> Stephen
