any one no iff norton firewall slows internt down
i have norton firewall installed some one has had a problem with zone arm, my conection is getting very slow any one any ideas
my pics on some web sites are slow
RE: any one no iff norton firewall slows internt down
lo there,i use norton firewall and i have not noticed any slow down at all,i keep the firewall up when im playing online games and it has made no difference to my ping times up or down.
Hi
I would always point anyone to plusnet's own download area if they want to see the raw speed of thier connection. Going to websites is a poor indication of the speed of your connection. When you look at webpages that other people are using the whole thing slows down especially if it is a poplular site or the hosted sites server is having problems. You can goto plusnets downloads page by cutting and pasting this in your address bar.
https://portal.plus.net/central.html?action=file_vault
select any category and file and see how pleasing that is!
doozer
All firewalls slow down the conection to some degree as it is filtering the packets some are worse than others.
