anti virus
anti virus
what r the best anti virus programs?
RE: anti virus
I use (and have done so for a few years) Norton. I would recommend this as i have had no problems with it, as long as you keep updating on a weekly basis.
One word of warning it will slow your system down a bit (depending on the system you have got (new / old)). But it is worth having the protection.
Another good AV tool is McAfee.
RE: anti virus
Most popular is Norton's, I use PC-Cillin and have had no probs, comes with Firewall etc.
You can do a test on your firewall at grc.com
https://grc.com/x/ne.dll?bh0bkyd2
RE: anti virus
> what r the best anti virus prograbeen running norton for 4 years no problems,running free A.V.G.anti virus as well trying it out seems really good might pay forit at years end.
norton is old [system works] and won't update.no clashes though.
:bandit:
espresso_mick
RE: anti virus
I can recommend Norton. I wont use anything else.
>norton is old [system works] and won't update<
Huh....eh!
RE: anti virus
I have used AVG from Grisoft which is free and is very easy to update. Touch wood I haven't caught a cold yet!
hektorshouse
RE: anti virus
AVG from Grisoft, its free and easy to use, also very good detection rate.
Also, very surprising, if you want to pay go to Kaspersky Labs and use their Anti Virus...its Russian but very very good.
Personally(only my advice), avoid Mcafee and Norton becuase of problems with Windows.
