another speed question
Hi
recently my download speeds have gone through the floor. My speed tests are showing that I'm compatible with dial-up (I'm achieving around 45kbps), when a month or so ago I was getting around 1500. I'm on up to 8Meg product.
I recently had Sky HD installed which is connected to the phone line, could this have had this affect?
TIA
seems alot of us are having the problem with 8 meg, i wish i never got mines now !
chymorva
Re: another speed question
...I recently had Sky HD installed which is connected to the phone line, could this have had this affect?
TIA
Most definitely yes ! All equipment which uses ordinary phone frequencies (phones, faxes, sky boxes, etc...) must be connected via a filter to avoid the exact problem that you described.
thanks Phil, I would have thought that the Sky egineer would have fitted one. seems not. I'll get on to them straight away.
DITTO! :roll:
I don't think their standard installation covers this - just buy a decent filter for a few quid, and shove the sky box in it.
As a matter of interest, if both my phone and my sky box come off a splitter from the master socket, would one filter do for both?
That's to say there is a filter plugged into the master box, then a splitter plugged into the phone socket, going to the 2 devices.
I've been fine for a few years, but just wondering...
chymorva
Yes, that is fine.
Liam
Quite true.
I once had a multiroom installation and Sky came to do it but wouldn't install anything as I couldn't produce a microfilter.
He had to reschedule and come back another day when I had one.
Hi
I have recently had Sky+ installed! I did put a Micro Filter on, but still I am getting real issues with my download speed! I have now raised my second call with PN (#20377944) and am awaiting reply! I am on 8Mb aswell!
This is really frustrating when you are used to decent speeds!
G
