am i lagging???
am i lagging???
I have been online with ps2 for a while now, and been told im very laggy. I use a direct connection to the ps2 and these are my router stats:
Connection Speed 1152 kbps 288 kbps
Line Attenuation 39 db 11.5 db
Noise Margin 23 db 31 db
is this bad? Am am a complete novice at this so please could someone tell me if these figures are good/badHuh?if they are can I remedy the problem.
cheers in advance.
am i lagging???
I' didn't wanna start anotherthread on this, bu I'd be interested to know whether my router stats are OK too.
Using a Netgear DG834GT I get the following:
Downstream
Speed: 2272 kbps
Line Attenuation: 45.0 db
Noise Margin: 23.9db
Upstream
Speed: 288 kbps
Line Attenuation: 25.5 db
Noise Margin: 19.0 db
Do these figures seem OK?
Many thanks.
Ripperoo
am i lagging???
jasonbrothers with those stats you have posted you should be on 2 meg service, raise a ticket man! men! :shock:
am i lagging???
Downstream
Speed: 1152 kbps
Line Attenuation: 39db
Noise Margin: 31db
Upstream
Speed: 288 kbps
Line Attenuation: 11db
Noise Margin: 31db
these are my figures at the moment...so, do you reckon these are good? Are these a good indication of whether I will lag?
am i lagging???
run a spyware program, if your running + net's anti virus and spyware try turning it off and see what happens.
i had this probelm i was running theres and mine own, i turned theres off and it cured it.
when your lagging in games, do you use uk or eu servers?
Play BF2? try this server 85.236.101.10 port number 16668 uk-base B2K ranked server. our UK run server! should not lag!
2 good programs which are free to use are spybot search and destroy. also mircosoft spyware.
Good free! anti virus avast home edition 4.6
Once again with thise stats you've post get on 2 meg ask customers services "2 meg!" You are entitled to it men!
