alittle confused so i need alittle help :D
are people paying to upgrade to 2meg or are people being upgraded for free < sorry im a little slow on the uptake as ive not followed the free regrade thingie erm do i have to do something to get upgraded? or pay some sort of fee? guess i need some help Shockedops:
Some are upgrading now, and some are waiting to get it for free, if their line can support this.
You can upgrade now for £14.99 (if your line is compatible) by raising a ticket in the contact us section.
If you wait for the upgrade, then you're upgraded automatically for free.
Craig
hillers
only a small percentage of people are likely going to get a 2mb upgrade, but 1mb is the best most people will get.
I think most of the confusion is that it was understood that we would all get the upgrade in april when in actual fact it will be june or july, which is causing a lot of angry post in the other forums.
