alcatel router
BattleRat
alcatel router
i have set up my system as a games server.
the internet can't see it
how do i setup the router to forward it to the internet
RE: alcatel router
RE: alcatel router
Which Alcatel router?
For Alcatel Speedtouch Pro Ethernet router you have to first turn of DHCP and use static addressing, then you have to telnet to the router and issue the following command this assumes your PC ehternet card has the following ip address 10.0.0.1
nat defserver addr 10.0.0.1
This command forwards all traffic bypassing the nat translation to your PC ethernet port and will allow you to run a games server.
WARNING:
You will lose any NAT protection benefits by doing so.
Make sure you run a firewall or else you will leave your machine open to attack.
Also take a look here for more in depth port forwarding for Alcatel routers if you feel up to it.
http://www.nzdsl.co.nz/howtos/Alcatel/alcatelpinholing.html
Ali
