adsl keeps getting disconnected
Everytime I get an incoming call, or I make an outgoing call, my ADSL connection drops. it takes a hell of a long time to get reconnected again, even after the call has ended. Most of the time I have to disconnect the modem (voyager 105) from the PC and the line, then slowly and methodically add the modem, wait, then connect the line wait, then dial. Even then sometimes it does not work.
vic_newey
a duff filter/ splitter surely
Sounds, initially like dodgy filters, not enough filters or bad wiring.
Check out the tutorial here for diagnostic measures and also follow the link within that tutorial to ADSL wiring and filters.
Well worth a read and may go some way towards resolving or at least identifying your problem.
