adsl freezing
Brickinit
adsl freezing
just thought this might be of help to someone. i recently built a new machine,nearly everything was new bar hard-drive and dvd player.the hard-drive was reformatted, so everything had a clean boot.
everytime i went on-line, after a short while the browser froze,not knowing if it was software/hardware problem tried all-sorts,eventually a reformat seemed to be in order.no joy.checked to see if components where getting a bit warm for their own good. things where ok. then thoughts turned to the modem, a360, tried to get some up-dated drivers, i think we all know the answer to that! anyway remembered support often asking people to disconnect their modem for 1 whole hour and then reconnecting.plusnet had been doing a lot of up-dating at the time,april. i diconnected for the hour or so, and what do you know? it blinking marvalous,back to normal, got to be worth a try before of you pull all your hair out.
malc
chino
RE: adsl freezing
thanks for the info...
cUnDaLl
RE: adsl freezing
It resets the dslam you know!!
