adsl and x-box
adsl and x-box
I have an account that is being processed at the moment and was wondering if anyone has an xbox sharing their connection with a pc. i have the router pack coming with my order and would be greatful of some easy to follow setup advice for both.
Cheers
adsl and x-box
I am currently using a Netgear DG814 router for both my PC and Xbox.
When I setup this, all I had to do was plug the Xbox into the router and it automatically connected to the Xbox Live service.
I am not sure what modem you will be supplied but it should be the same straight forward setup.
If not post the make and model of your router and I will try to help out.
Cheers
Scott
adsl and x-box
when playing on Xbox live, dont do any heavy downloading on your PC, otherwise problems can appear ( especially when Using the headset and playing)
