adsl activation
adsl activation
Exactly how long does it take for BT to activate a line, i got an email saying that my line is ok, and have bin charged how long should it take from then??
chris
RE: adsl activation
Hi Chris,
At this stage you will have passed the first set of tests. BT now need to visit your local exchange and do more tests, if these are successful your line will then be activated. This normally takes 5 working days.
Kind Regards
Kevin
| Kevin Revill ............... Unmetered & ADSL solutions
| Technical Support ................. for Home & Business
| PlusNet Technologies Ltd. ....... @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet -----
RE: adsl activation
Ive read about so many problems, are they likely to happen to me?Huh
RE: adsl activation
Hi Chris,
The answer is that it is unlikely to happen to you.
Occasionally BT will find that an ADSL connection does not work after they set it up, due to faulty equipment at the exchange.
This is normally resolved within a maximum of 4 working days. Depending on what the issue is.
Kind regards
Kevin
RE: adsl activation
Wow, lines are usually activated within 5 working days? thats impressive, at least it would be, if it wasnt for the fact that i got that email saying my lines fine 6 days ago and still havent been activated.
RE: adsl activation
For BT, working days are Monday to Friday. Thus you have not quite reached 5 working days.
As soon as the ADSL is activated by BT we will inform you by a phone call and/ or an email if you are not available.
Kind regards
Kevin
