adaptive speeds?
adaptive speeds?
I was regraded to MaxDSL on the 19th and have never got over 4000kbps with online speed testing, even though my router is syncing at 7840 kbps. What I dont understand though, is at certain periods while using P2p i was downloading files at 600k.
My question is does Max Dsl adapt it's speed to the task in hand? So an online speed test will never be accurate to get your top speed? But as my P2p speeds show, it will go further if it needs to. Or am I just talking crap...!
