a solution to constant disconnecting
I used to have a 1mb service and i had it running upstairs from the bedroom.
I never had any problems downloading at max speed.
As soon as I got a regrade everything went to pot.
Broadband kept disconnecting.
I thought i tried everything to solve this and it was something really simple.
All I had to do was plug it into my master socket downstairs and connect it through a wireless network.
I am using the netgear dg834g and although it was a wee bit pricey it is effin wonderful.
I thought I would share this with you all just incase a similar thing is happening to anyone.
I would be interested in knowing if this has helped anyone.
Simple solution yes but as i said before 1mb worked fine from another phone socket in my house so i thought the 2mb service would be fine but it wasnt.
Have you checked your wiring against the Wiring Tutorial? in the Tutorial & FAQ section on the Forum.
It could be that something isn't quite connected up right.
Aaron
everything is sweet since connecting to master socket,
maybe my post wasnt clear
Sorry It was my fault, I should have read the post more clearly Shockedops:
*ground open, swallow up* lol :lol:
