Zone Alarm Pro versions?
I currently am using version 4.5 of Zone Alarm Pro with no problems. Read a while back that the latest version 5 had various problems with it? Would anyone care to comments on the merits of upgrading to version 5 or is it best to stay as I am?
I have a friend who is using version 5.1on his system with no problems so far so would it be fair to say that this version has had any problems fixed?
I'm lead to believe that the problems have been resolved in 5.1 but since I don't use ZoneAlarm I couldn't say for certain.
Aaron
Yep, the latest ZA and ZA Pro are good to go. Almost all the problems experienced with the first few 5.X releases have now been solved. I have been using it find for ages now.
