Xbox live.. ping test?
Hi is there anyway to test the ping/latency on xboxlive?
Thanks..
Are you using an orignal xbox or an xbox 360?Huh
Hi thanks for the rpely
Its a 360..
I ran a few ping tests on the PC and according to BBST to the USA my pings are ok BUT to UK and European servers it says "very poor"
USA average: less than 120ms
UK: 50
Euro:70
those are approx averages..
ah, they did have an information page that could be accessed on the original xbox, it gave ping and latency details.
Microsoft removed it from the 360 to cut down on the number of support calls with people complaining about bad ping rates etc.
I dont know of any other ways you could get the information.
Maybe somebody else knows?.....
Thanks..
I also have the orig xbox so do you know where on the dasboard would it be.. Network?
1. go to settings
2. go to network settings
3. press connect button
4. after you're connected press Y button
That should give you some details.
Let me know how you get on
Hi just tried that and results at 5pm..
L: 182ms (214ms)
I`m guessing thats the ping.
I will try later tonight to see if it changes..
Do you know the IP address for the xbox live servers as I could just run a ping test from the pc to them..
Thanks..
Well I have tried at varying times.. late .. early etc.. and the numbers stay very much the same.. :x
I have noticed that although I only live approx 150 - 200 mtrs from the exchange that "interleaving" has been activated on my line, from what I have read this is bad news for pings.
My other post gives the router figures.
http://portal.plus.net/central/forums/viewtopic.php?t=47616
Any advice
