Xbox Live
Xbox Live
Just want to know of anyone that has managed to connect an Xbox via their plus.net internet connection and if so did they come across any problems?
Cheers
S Ot
Xbox Live
Hi Ot,
I connected my XBOX to my netgear router and it just worked. No messing about.
I hope you find the same.
Xbox Live
How about via my Binatone DSL modem? Anybody?
Xbox Live
I am using ics very simple to set up. If you mean a usb modem you need to set up ics to get it to work
Xbox Live
So how do l set ICS up exactly or is it best to contact Plus.net directly?
Cheers
Xbox Live
otstuff,
Carry out a search on this forum for ICS or XBOX.
There is lots of information on how to do this and how others have.
Regards.
Xbox Live
does anyone know if it is possible to connect the xbox to a wireless router?!
Xbox Live
Xbox Live
I managed got my xbox working through my binatone adsl modem 500 just fine.
Set your connection up as normal, allowing the sharing of the connection.
Then use a crossover cable from your network card to the ethernet port on the xbox.
