XP SP2 and Cablenut
XP SP2 and Cablenut
Just a heads up if you use Cablenut for your tweaks and have upgraded to XP SP2.
It appears that the priority on the DefaultReceiveWindow has changed. Whatever number you have in there set on Cablenut, will now be used as your RWIN.
To get around this I just blanked out the DefaultReceiveWindow, this gives it the windows default and then any tests/analysers should pick up your correct RWIN.
