Worth trying
Worth trying
I fitted an NTE5 ADSL faceplate (ADSL nation) and sync rate jumped by 1 mbit/s - so worth a go for £12.
Alecto
Worth trying
Mine jumped by 1.5Mb when I changed to a Netgear DG834 router. :lol:
But I run off an extension, so there's no point changing the face plate for me.
Netgear Router
What download speeds are you getting with the Netgear compared with the previous modem?
Alecto
Worth trying
With the Solwise and Safecom/Origo, it synced at 4,500 and I got a max stable rate of 3.5Mb. Speed tests shoed about 3Mb.
Now syncing at 6,200 with a stable rate of 4.5Mb, though it was 5.5Mb until a week ago when the line must have gone a bit odd . Assume it will go back up in time.
Speed tests show between 3.5 and 4Mb. (showed 4.5-4.8 at the higher stable rate).
