Wireless routers (Speedtouch 570)
I'm thing of getting a wireless ADSL router, my initial thoughts are on the Speedtouch 570 from Alcatel.
Has anyone used the 570 - would you recommend it ?
Or any other wireless routers you think are perhaps better ?
Thanks in advance.
Oracle
<< Fast forward into the future >>
RE: Wireless routers (Speedtouch 570)
Theres a couple of others roundabout the same price
Draytek Vigor 2600We (£191+vat)
Zyxel Prestige 650HW (£239+vat)
I remember reading that D-link were about to bring one out as well.
I was looking to buy one, but decided to go for separate adsl router and a wireless access point.
Note although the Draytek looks good value it seems many people have problems playing games, although whether this is down to their setup or the router I don't know.
D-Link have 22MB wireless technology - well worth considering if you're going to move significant volumes of data around your network. Wireless technology is getting faster so if you opt for a seperate router & WAP, you'll only need to replace the WAP when you want to upgrade.....
> Thanks in advance.
> Oracle
...and if someone draws a circle with some strange squiggles in it on the pavement outside your house I would start to worry...
http://www.warchalking.org/
funny enough when my next door neighbour bought his wireless network he didn't bother to set up any security at all. To teach them a lesson their son drove up in a car park opposite the house and with his laptop and accessed their network. Lesson learned!
Thanks all for the info. Point on security taken.
I'm also persuaded by getting a separate WAP now - BatCat you're right in bring this to everyone's attention.
In which case I may go for the Speedtouch 510 v4 with a WAP add-on.
Oracle.
