Wireless network and ADSL
I've been on +net ADSL for some time now with a standalone PC and a DSL-200 modem.
I've just got a portable and would like to be able to network the two and share internet access between them. I was thinking the best solution might be a wireless switch/router. I'm happy with the desktop being hard wired, but I'd like to be able to 'roam' with the laptop (check email sitting in the garden with a beer, check share prices while I'm cleaning my teeth, and so on).
Has anyone done this, and can anyone recommend some products which work well?
Thanks,
Neil
brianhig
RE: Wireless network and ADSL
Hi Neil
I use a Netgear DG814 router with a 4 port 10/100 switch. Connected to one of the switch ports is a 3COM Access Point 2000 (about £120) and on my laptop I have 3COM wireless lan PC card with an X-Jack antenna (£60). Works a treat.
I can carry my laptop around and can surf the web. Works up to about 100 feet.
Wireles LAN is currently 11Mbps but since ADSL is only 512K on a good day (and it has been pretty steady in my area for the last week or two - touch wood) that's not really an issue. It is worth spending the extra £5 or so to get the PC Lan card with the X-Jack antenna as it is retractable and doesn't get in the way when you put your laptop back into its case for carrying around.
Hope this helps
Thanks Brian,
The setup sounds good, but I guess what I was really after was a modem, router, switch and wireless AP all in one box. I saw a Linksys wireless AP/DSL router w/switch for about £100 on Amazon, but this requires an existing modem. I assume my current USB only model won't be capable of supporting this?
I've decided to go for this anyway, so I may well copy your setup (the DG814 sounds good, looks it too).
Thanks for your advice, and the tip on the X-Jack.
Neil
