Wireless Networking Help
Can anyone help I have a machine using W2K with a pci adsl card and a netgear wireless pci card installed and want to share this with the kids pc running ME with a usb netgear wireless adaptor any help please. Thanks.
1 REPLY
RE: Wireless Networking Help
You would need to use some kind of ICS software, internet connection sharing. I think windows 2k has one built in not sure, if not Im sure you can download one, if not you can get a third party one, try downloads.com. Dont know alot about this so you are gonna have to ask around sorry.
The second and more expensive option is to get a wireless ADSL router and use that instead of the ADSL card, personally i reccomend this option, then you are not using resources on your machine, plus you can connect from the other machine when your PC is not on.
Hope This Helps
Aaron
www.fluiduk.co.uk
