Windows XP & Binatone adsl500 problem connecting
I tried to connect using winxp pro. I was able to connect but page would not load, not receiving data . This does not happen using win/98/2000 which is what I am using now. Has anyone else had this problem and if you have how do I solve this. I am using Binatone ADSL 500 modem. Thanks
Do you have XP service pack 1 installed? You need it for that ADSL modem to work properly according to a few other threads here.
Also are both the XP and Win2K systems on the same network (and both connected to the net through the modem) or have you moved the modem to a different PC. i.e. the XP PC and the Win2K PC are different systems? Or are you duel booting the same system?
Cheers
Peter Cool
Thanks regarding binatone & winxp
Guess xpsp1 is my problem, I have not installed it becauseI have not been able to use windows update due to the modem. Looks like I will have to find a download site that has a copy of xpsp1 as microsoft does not give me the option to save to disk.
Anyway thanks Peter it looks like you have solved my problem.
Mike
csogilvie
XP SP1
130ish MB
XP SP1
Thanks Colin,
I have downloaded xpsp1 from the link you sent me and everything works fine now.
Again many thanks
Mike
