WinMX problems
WinMX problems
Does anyone use the file sharing program, WinMX, with their ADSL line? i just got my ADSL modem today and am having trouble using the software.
If i set my connection to show as DSL, i dont get any results when searching for a file, and therefore cannot donwload anything. if i set it to unknown, i might get a connection if i'm lucky, but it will be worse than my 56K modem.
Any ideas?
RE: WinMX problems
> Any ideas?
In brief, all P2P programs have been classed as 'low priority' and we all give down/upload performance worse than a 56k until the new 155Mb pipe is installed which may not improve it much.
RE: WinMX problems
> Any ideas?
Why not try Kazaa http://www.kazaa.com/en/kmdstart.htm
RE: WinMX problems
> Any ideas?
One of my family uses WinMX ans was sufferring the same - try it now as it looks OK (re 28/04). Previously there was a problem with peer to peer comms having low priority - or something.A new ADSL pipeline has been installead an this supposedly overcomes the problem. It looks to have done so to us anyway
