WinFax has stopped answering
Since getting ADSL my WinFax software has stopped answering my incoming calls.
Has anyone else suffered from this?
Is there a fix?
Is there an alternative?
Fax software won't work with an ADSL modem! That's because Fax software requires access to the voice part of an ADSL line, which is the part used by a standard dial-up modem, not an ADSL modem.
Thomas
Would it work if I attach my old fax modem to the "voice" filter into which I have plugged my phone?
Yep! That should sort it out just nicely. Smiley
Thomas
I'll give it a go, thanks for the help.
No problem.
Thomas
