Why does my Accessrunner network connection hang?
:confused:
Since installing on Wednesday my network connection on drops usually mid way thru a download. The dun/network tray icon stops flashing then all connectivity appears to be lost. The access runner icon still reports activity so I disconnect the DUN session and everything goes pear shaped from then on the network tray reports a not responding close dialogue and eventually the whole system dies requiring a hard boot. After that and assuming plusnet's end is ok it works fine......... till the next time.
My USB Modem (conexant)'s RDY light always flashes - is this normal?
I am using XP Pro
Has anyone else had this?
More to the point has anyone else managed to solve this oneHuh?Huh
