Why does View My Usage SHow Brodband Phone Use???
I have just checked my usage and it shows 190MB of broadband phone usage. I have never actually used broadband phone. What is casing this to show on my usage?
Classifying all the data that is sent/received on your ADSL connection is never 100% correct so some data may appear to be VOIP even though you don't use that service. PlusNet use various ways of detecting the traffic type and one of those is checking for common ports that various VOIP software normally use but these ports may also be used by other applications or games or even things like P2P.
It's nothing to worry about.
Thanks for that.
