Why do I keep dis-connecting from PlusNet
As teh topic says really. I still maintain teh ADSL connection but keep dropping off from PlusNet
This seems to occur particularly around when teh phone rings on and then off
Any ideas on what I could check
Nigel
RE: Why do I keep dis-connecting from PlusNet
I got this when a phone that was not going through the spliter was picked up.
Same here
Yeah i had this when I first got ADSL. is the line noisy at all.
First try it with a spitter and ADSL on. Then try it without a splitter and just the phone into the socket. If its noisy with just the phone call BT on 151 and tell them.
You could also try different splitters.
> Same here
Well put the phone through the splitter then.
> > Same here
> good advice mate, if the pc and both phones were in the same room!!!!!!!!!
