Why do I keep Getting this
Hi can some one at plusnet tell me why I keep getting this and I havn't got a virus my pc's are clean getting right up my nose this is
We have detected a possible Worm Infection - Immediate Action is Required
I take it that you are seeing this as a web page?
If so then somthing on your network is using port 135 outbound hence the warning.
If you have fully scanned your system(s) with fully up todate virus pattern files and are confident that you are clean, then identify what is using this port and lock it down.
Failing that raise a ticket.
Thanks for that m8 I'll check it out
Cheesy
