Who do I see about Interleaving ?
Just wondering if Interleaving is default enabled or disabled, if enabled do i need to ring the normal number to have it disabled ?
For MaxDSL the setting is Auto which means if the exchange thinks interleaving is needed, it is enabled and when not, it is disabled.
For LL it is on by default and currently cannot be turned off.
Somerouters will tell you on their stats page if interleaving is on or not. - what router do you use?
If it is on, you are on MaxDSL and you want it turned off then you need to raise a question asking for it.
Thanks for the feedback !
I am on a standard DSL connection since they won't move to me to max due to problems nationwide. My router is DLINK G604t.
If you are still on fixed-rate services, then you won't have (or be threatened with) interleaving full stop. You will remain on "fast" path mode.
