Which service or remote video web cams
Where have the comparison tables gone? Is it just me or is there very little detail about each of the adsl accounts - only what is costs!?
I want to be able to set up remote webcam (live video) on a construction site. So which account would best suit, 512kb would be fine - NAT or NO NAT?
I'd need a static IP for the camera.
With a No-NAT account, do I get a single static IP address. Could I have the camera located on the internal network (192.168.0.1) and then have the router "forward" all web traffic to the camera?Huh
Yes.
Both NAT and no-NAT provide static IPs.
The differance, is that you get a block of IPs with no-NAT, rather than a single one.
This means that a machine inside your network, can be assigned directly with a public IP, rather than a private LAN IP.
You can use the no-NAT method, as you discribed, and forwarding the connection on the router to the desired internal IP.
NAT option would be fine
The NAT option would be fine, since your webcam software will be using a particular 'port'. With NAT you would set up your broadband router to route all requests off the internet for that particular port to an IP address of a PC.
