Which of the hardware that plusnet sell supports VPN
bluewhale
Which of the hardware that plusnet sell supports VPN?
Any other recommendation for ADSL hardware thats cheap and supports adsl.
RE: Which of the hardware that plusnet sell supports VPN
The PCI and USB modems both work as a direct replacement for a standard modem, ie your machine is assigned real IP addresses and all services will work without further intervention.
The Solwise SAR110 router we supply supports IPSEC forwarding, so VPN protocols that use this will work fine.
Regards,
Ian Wild
PlusNet Customer Support
bluewhale
a cisco 827 will do...
