Which is the most reliable bandwidth measurer?
I've got NetMeter running constantly, and it always shows i've used less Bandidth then the PlusNet Usage Meter tells me...
Which one is more likely to be correct?
1 REPLY
Do you use a router or ICS? Although ICS usage might be calculated with NetMeter (if the host computer is running it) - this wouldn't happen with a router. So if you're using a router, or running NetMeter on the client ICS machine then it's less likely to be accurate.
That said, PlusNet have acknowledged that the VMBU system is slightly dodgy - so it might not be best to rely on this as being 100% accurate.
