Which advice is right?
When Plusnet emailed me to advise:
During the testing period you should frequently make new
connections to the Internet so these tests can take place. It's a good idea to power off/on your modem or router when doing this - this will force your equipment to reconnect.
by "frequently" do they mean once a day, as their advice video suggests also?
I've been turning off my router every couple of hours!
Depends what you sync at.
If you sync at full belt (812Cool then you might have to resync once a day.
Personally, I just left my router on permanent. If your line is stable and you have correctly configured premise cabling, Max will work how it was designed to and find it's own way fairly sharpish.
I'm syncing at 7616. I think I'll just turn it off at night, unless someone tells me the contrary.
Isn't that Plusnet email a bit misleading?
Yep. ISP's and BT cant seem to decide the correct methods. It's probably because even BT don't know how their product works :?
