Which Pipe am I on
Nocturne
Which Pipe am I on
I understand there is at least one 'bad - slow' pipe which may be THN-AG1.
Can anyone confirm if this is correct and refresh my memory on how to find out which pipe I'm on.
Fixes: 57
Which Pipe am I on
I can never remember the link so I just open a DOS window and do a tracert to bbc.co.uk
Nocturne
Which Pipe am I on
Is THN-AG1 the pipe in question ?
Trace:
1 89 ms 99 ms 99 ms dsldevice.lan
2 58 ms 54 ms 56 ms lo0-plusnet.pte-ag1.plus.net
3 54 ms 54 ms 53 ms ge0-0-0-403.pte-gw1.plus.net
4 57 ms 54 ms 56 ms ge0-0-0-22.ptn-gw1.plus.net
5 54 ms 55 ms 54 ms gi1-1-22.ptn-gw5.plus.net
6 56 ms 55 ms 56 ms rt0.thdo.bbc.co.uk
7 54 ms 53 ms 54 ms xxx.xxx.xxx.xxx.
8 53 ms 54 ms 56 ms www52.thdo.bbc.co.uk
Moderators note by John (johnessex) Full quote of preceding post removed as per the Link:rules
Slipperymack
Which Pipe am I on
This will take you to it -
http://usertools.plus.net/@gateway
Hope it helps.
ady
Which Pipe am I on
"You are currently connected to the "Telehouse North, Juniper 5" gateway. This gateway is sometimes known as thn-ag1."
well i hope not -.-
Which Pipe am I on
"Telehouse North, Juniper 2"
Currently getting 1600ms pings. I'm totally sick of this bs.
Which Pipe am I on
Pings seem particularly bad for me tonight with little difference between them.
