Where is the speed test?
I have seen a few posts refer to a 'PlusNET Technologies Bandwidth Meter', and the ticket wizard mentioned using it but did not provide 'the link below'. I have had a look around the plusnet portal but have not found it yet.
I would use the ADSLguide test, but browsing anything other than the plusnet portal is almost always impossible when I try.
BTW 23 hours so far on the ticket and no response.
Mike Beard
RE: Where is the speed test?
heres what speed I got from adslguides speed test
Your Connection
Direction
Actual Speed
True Speed (estimated)
Downstream 12 Kbps (1.5 KB/sec) 12 Kbps (inc. overheads)
Upstream 147 Kbps (18.4 KB/sec) 158 Kbps (inc. overheads)
Quite fast wouldn't you agree ? Wink
Here's what I get
Your Connection
Direction
Actual Speed
Downstream 466 Kbps (58.3 KB/sec) 503 Kbps (inc. overheads)
Upstream 229 Kbps (28.6 KB/sec) 247 Kbps (inc. overheads)
And the answer to your original question is
http://monitor.plus.net/
Steve
> Your Connection
> Direction
> Actual Speed
The Plusnet Tech. Bandwidth meter can be found at the following:- from the portal click on "customer support" link on the left hand side of the page. If you scroll down the list for service statur etc. (on the main page) there is a link that says "live server monitoring". Click on this and from the new window that opens, you'll see the link. When you click this, it opens a further window and you'll get a bandwidth test for downstream.
Thanks everyone.
Turns out that my speed is fine, regrets and best wishes to those who seem very slow.
Your current bandwidth reading is:
484.60kbps
which means you can download at 60.58 KB/sec. from our servers.
53.3 kbps 56k Dial Up
64 kbps ISDN 1 Channel
128 kbps ISDN Dual Channel
484.6 kbps YOU
500 kbps ADSL 500
1000 kbps ADSL 1000
2000 kbps ADSL 2000
Just makes the fact that my web and mail service beyond plusnet is so slow it normally times out all the more strange.
The ticket number is 6078724 and it was posted 2003-01-10 19:55:18.
Thanks again Smiley
Michael Beard
298.30kbps
which means you can download at 37.29 KB/sec. from our servers.
i tried just now!!!
is this means quite good connection?
we are not pay for this poor connection.
sobia
Progress :)
Congratulations to support, got it right first time. They asked me to try with my firewall turned off, and it worked fine. I am a new ADSL customer but have been using 56k on this PC for months without problem.
So, why would Zonealarm cause such a problem with ADSL? Why doesn't the problem arise when looking at plusnet? Is there a solution?
We will see what support comes back with.
Mike Beard
espresso_mick
DSL Reports in America I get: -
469 Kbps down
255 Kbps up
With the PlusNet monitor I get 495.30kbps.
Smiley
I'm still using the same settings I've used for a while now: -
MTU = 1458 & RWIN = 12878
Normally if you set your RWIN too high you will end up with packet loss. Have the people who have changed it to 64240 not noticed any or have you tested it?....just wondering.
Zonealarm solution - should be an FAQ?
From http://www.applecomm.net/L4_R_faq_Section3.htm (thank you google, though it took some finding)
ZoneAlarm Configuration
If customer experiences problems browsing the web while they have ZoneAlarm Firewall running, then the following must be done:
Click on Firewall.
Leave Internet Zone Security and Trusted Zone Security settings to default (High and Medium respectively)
Click on Advanced.
Tick the 3rd Checkbox Allow Uncommon Protocols under High Security and press OK.
After this, refresh the page and you should be able to browse to any website. The problem lies in the fact that ZoneAlarm does not consider PPPoE a common protocol and as such will block it under high security settings
Michael Beard
×ïºÎ õ#ùxù!ü/{úœ!ý�î�AÄ«ÈÈäeO¤_‰¹W�˜ÿàtûg)ý{)C>80ú¿sP\9ÀÇü·8säaq‡þŸwè÷:,îÐïuXÜ¡ßë°¸C¿×aq‡~¯Ãâý^‡Åú½‹;ô{÷¿BðdX[à7°™j…Û]0=Žé ÉÍ Ìö¬øª��õ1I -jÜ<-j¨;ÌÐæ틱œ0¬àµ�>ÄÕKƒ~P�æREN³eÊǦÝí ~ã5§âµúT¼žº¨êÇšö…‘–ë„*G‡¿Ïs_…zìQ€¡¡tA�Þæf§N+²;Ìbô¶'qµKÀ‚ø†FY{€:Fgguccuc�˜€Òg@˜–ŽHs_³aÎaNæ‚}ÌÁ320è°ƒñ%'êV™G¦¼R¡‡ÏQ/9úgä]Ÿkþ-C3ãðƒ'Ò‘Ãy®¥e„âǸPÒ«q™ã×`ß°è¸Ìb¸YQÑŽÚ¬” Q…È|û’óðàŽ]0$e�[Ö¿vðzqÜÝ+c¢ªSwÞ„Q৒5㦯�‰3¯Â²áŸ©‡¬ü[x!ºpGÇÜûÐ2õº`ý�k»$yÖ0ÏàBÖR\Ñ'™Â1¼g&÷/‚rƒdºÖýÓ­Ÿ¿h„P¾TúÔ˜ÛP„Ï�…¿ãÀ,È×'zˆ›V/õXÙRW,Âtš‚7ÈayOaÞçÜYÒ¢ÚŸ«³¼˜•ºîe¢¿ißØ©¶1º'œ7¼üà£Ûöâe-Õ¢&ÍÐuQ›S&ù >æZpÄð{,}ã å éæhèé'z)24IÇ7v®©zÞ¤bïÍ襡֒âKîb½…Ú48´Ü³Í!í%Î�ᙕ{¥é�kOþáwmz|Ó±èŠïƒ+Â$ý›å*V:Ó–?UìØ>¬µ:ô¿8Á1M‚%]Sp¬ÿÖi‰žlž|µl*u½ùÝòÙ7꙾ÎÕ£i,¾�!9.³´€™k…ÉpÙBúq‰0tCBL:—$Û"þʤg¨N�‚ ¶TÊçYeØ1˜Ô”æÉa¸ê‘Í"-m�Èþçg¯¶6™¾µŒ©¨WIâJpâ«Æ¿º¢ò?j¾Ûb~¶q]Ð " {Ú½jUàuU,/m}|$³Äñæ˜ÙZ¯Hí 1‘ˆäAµ;Õ�GªIceRSbY*‹›.}Œ‰x}·ñ=~H¸=ëÝL“ØE‡u{ÙI—I©ãié0ê<^À"š‡ïZ3ÍpxÜŒå`L²gyø”‡£Ô�eD}±2Œq©$sCÃ/G«3ñ4Úgß9Rò‡<µuŸzE„ËB»dÁ-#îÊCI·Ù*ä­h;YR‚ËÈuÌ£'ËšC@.AóèƒâHdv§˜…�s…ör— õdÍÜ ÍxÔ*å&[�bÈ_}>í†éÓœ>QåmwS^]þþ•#¹„ˆs{4–c¥Ýý/»’*f£–À ¯êª‚MÃÅÔE¦³fw‚Ú¡�›mO'áPj‹q¬e(UpÆ=¶¤ÊÁ×wnîX�U|qÊé*¥åé/×£®k¦þ}_âES€õ~Ã˳þ&{5g¤Ö÷×N¿]¾±§þÇŽk™uNÉóe•�+#Î4ïîg:"â¹úÏELq×=Ý\È^}Ü”™Á´fÜ3¾�ÈÕ·7Ü8i±Íý‚l)Hf}¢Í»äk‰ÃØ4žRž×t9.>d˜¤™P[î¯ɨ‚Ý(0³C5á j“„°ôáNw#ðpJÖ'H—ìu¼šùÅÝ1:ó.‰Í*Ìç•Y8J[Ô~jàõm×AõìA•¶‘*X'9íµyÃôh«ÿþ\Jl‘�ŸñSˆ/·¾ŸÙ‘M†¯—ÊÅøzŒQ«™`§ E4$y“Kˆ¼ÞÞ¦>sp¨6rD(Éäõ"Æ8mq´x=¯€Qç©h–1Z½Ü kEC€ÀòÚFNÿü‚JL½ÅG›9§@ !ó"æ)‰0–oO/<‡ÑCYY1¹×aÅ–ìg”wWâ­à9'˜ÑOü©ó(6^>tp¹�0Œ³4Ôrs3„üé7íç»g›O;ð¸K?_”§p?t‰UÒ�¸“ʼn@[_ÿwÏGrXYê|X:•º5k»ŽNoÊmÕTE¡ÎŸ›VîªïüŸOÃÏ‹�˜LzV¢½¢0oA«ÜIK`ÜcûU\*À órøpÙW ÀwV¢¬¸Ð,Åø ƒ Š’õy®ŠfÙrªi Á†ªŠ&߶Ëk r»P �É6'óÓZ´žZú:=w´d¼ˆ!¬•ÕäxË�ÈèDXg]§a¿£–í•8lË“|_¶g;«—™§\f>Ç\¶]ÓT�÷¹2™é]íjþÚ¥_HÄ-Q‰daâè”\='O2gœƒ,‚C$A’8jƒêEçImxm)ô:­8ƒbùWl¸èz B�>Ùµ¸x~4T>kF¨Èañë(bSYÒ¿•ÇebD¸I7èé2ãØ$L;‡D»@<5ˆü~œ™ç.ê^ù`ÅÖ>¾7 Úó×òø(^¦pCq³•;h …‹ûkŠ8Çé¥Øæå˜Dë9ë·odÇ·ï™Ù|´9_9Ü‹Ÿaª”ÿ Ðq¢ön/š=Qt¢)¾-×n}û®³3²Xû³S!Q^6ÄâÔÉ#93#ûFO^´þðÜŠúùåik¶óŸ¢ôOm’ãÕlÙŸQÅ<[5QÅ<­ÿ2&8r"±¦ÍðöÀDƒ¸á¸½[Q÷ÝjèKYš.)ï1—YnF¸£ÝKå÷ëߦÿ™â¥akÛÃÖjù`…R+´[b !_M¼˜æ€ÓºM¶) Ö@ûÏ;ì0^904ؖΞʃ~Ö3xKB?XÓ8ÉÇÝŠ£± ÊŒôJ6 +ñ{¹ñA ;î,öêš�§øù‡cÏ7Zê�Ó¬u„v]„®¾$¨1XÁýyÍ��‡x,º�̤;å·ýwŒ&l³,ŸãY»Å×�³¿qzèÇâ“UIìgPlÒ'uWÒsô«¦r/•µ%Ã×K>ö'öÇé†ÙñÚa×Õ¿m¶¯ÅBІß]Ø$Ý]ÁB°ÙÔ¨FŒ0nþ¡fò£Óú~TίŒÝûõwàd5Tongueï�ñNÔ#d{[ÿèzK^L�%” cE&“IÀ©¶‘•OÄÜ^YOë®$¬ù³ú 2—ÆŠÂjåóÒVt�D³§ZiF’Ï·Kø¬×F åþÖJÞ}™“Rr\Ð|pL‰,Ødê vã૳‚}ö½ô¼‰M‹ˆoŒ´’fF&Œh*óê«€UÄb怩Ì¥ø H—ø‰{}Eò}a Qï•g¯À¹áι1ZìÖçtí# s†}';=¢=çêö—‡iljG¨p4Qr”4/ k,Òårå\¼ÿR×Úú'ž›Ÿ¡¾}¦½Êu·O–Þ½¬Ã`µsyŠäFA]Ï$*Äñ](ƒX²ÖUŸn¿E9B±²Òg Z[^‘å(ƒ8àYž¼XLiD]Z-áÁ”tdRUhÌÝ (SS7ÄÕýQEª‚#‘suZHÓí!ºBç«G�à2¯ðjææîÐåôUS?«æ²Æ¶ ëó)·-îú+µV¼ÚžòžZ‹ä©¸ÀŒQ¸#¼÷}„�w_×ra4Ÿ:c‰Ø;¡dð8iÛã×´)sÃ?QÌÓeö�Š{TðW(Þ`µ:þɃÁJ7;™Ò¡DKjPÁ #–ÿWq�Û=£‘ÌÔžOÖ•c$Õ<ÁÒ sµÌWIï³ëKVPeµ è}�3‹i¿ãñ¸F¹<öÒ­@׃:/vOZ*9¸¤µâ¥ò+ð Øþ´ÒmÜJ^â@ûÒÉ� KHµ�–%�Òƒ5zݱj@<·F)$Ø´ >~÷nânS6îHRŸ¾c-ÜüöùœêÏÉÖbc&�-‹µˆ‰·��“f.&¥r¥28îH 0¢<žš\¼j~CìúË–òšêòÉ„H³˜0^´¦^» èR`Õpær%yõÕ&üièG”b)Þ÷[óž«b¾ÿ¯´kÝbZ>•vƒuSTAãzF¬‘ª*{þ’IJ³ŸÃänÅVÅ®ŸñšˆÙvþqõô㉶Wþº‘/lºfh·Î\cÚï£öbý)YvNyîo#�M@g*Ò’ÅexOÆAØâãYAü ×ðB¸˜²:4PB®£°²4’W:[âcýc¨&ûYiN+®À©½*¿¿.Æ×*ë³íìÉr¼cµœÓ+getb&@¥Æjw`”dÛóíÌã#¦3ïq´Ib·%ƒDEšž 3&ð/�eqBÐmø Äý§ªÖ÷˜ÌoÑ)­ã^Óä¸ã”K†ú&À°tï[ ñì*ƒ/W4e°’PíÆfïJªIRÅŠ;p”Ù _ÌÇy#ÆêoJgDâ¶ðx3,˜Ym¸4Û1Þwf¶Ê¸óX§³×ìE+“ùwy¹ Nšé÷¡0}nøˆ÷T›+žßœÐa!…Àðñç¹it}<È`—¡Q¹Ü1iÁTÃt$é†'¶m|þS—„¦ºÉã®u’Jƒ �fìÅ Ëú�©|)A¯Íé…åÍÍ•æ·ÿö¶�Çl÷Í£¬�šÂmž…§‡…Ƴ+9€5X›‘b:`P(¤[âêø+EÚs’š†póóHŲÊ9Õ˜ô²A¹ùMôôÔû)WׯuÌ:&³F#!–Ÿ;‘^p«á²ìÁ;7ãã-5Ûžfy°çzs¬^õb­F7ÇO¹�Ñ\×»”P§]¯ež½séKÞ9üe¬Ë¾JÛ·G—·š�;K/íÁmÇÓ8%¢Ìui§NôþÖ~h«ý–ËžjØâÔÜB·ª47ø?4]eTÑÒÜÝ ‚»»{pwww—à®ÁBpO€àîÜÝ‚g¿Í{ï;‡åßîé©®®®ž{ïL .P”ne �$‘QÁ¥ò�q™Ìš“|h\±³ý°O¢ ~%N^ ‡"UCô9Uxñ,Kf "¤øü'å d¢ .b†† ¨*hܬ@fø3:ïí XÄŒZ‰”8h•PµÒØ‚¨™ŠÈ¤¬Õ!fƵÏ1°QN„¥æóY²NŽ�toãCoä…'îÑA"ÒÈ"dPÄÀúÀ6­4WÁ€DPA¬ùNÕ¼Œë—èê v 9Kئúñ“Ô¯Ù›ï[ 3°ÿYdb… èï‡Xçíü&ímƒG:T€Ç—ŽÊŠ%DðµÀ†€Ào:á¡Â^±ÃdéC*&U“v+by‚„@ø6õÝBå-�ßÍ+T!‹g&÷'RmGÃú%/ceøï´ò+Ð[f±¨t9ár�£Ę%LH”z2YyÚ˜Ôpó‡�ÿïª@çF<Š¥z ¸%å-¡à1¥ ‚ô~QU“Ñ0‘48(±(d…ô{á:=áZ<_�Ü6,õq#™¡ µýÞ5ïVîVO B8 ¯‹q;*JõTŒu§*/]„L,ÓiòDv¤ 5xÀ<‘O¾‡ÐU�Q�Œ=š�SɪÈv;÷^/ô˜™Qø<Íý¿ˆæëwœ]¡¶ñàóÂmy‹O¼!àˈü$y±?Ê7¸qõòòŸB¾f�F¢CÀ<ÊšB‘ì‹ùïëÙ“5lJ'Ó0žL™€ µf ²øǸ zÃZ1%¢x6„áiÉ|6› ƒC¡´.†‹íÌ8›¡¡PXñˆ¾‚~qå‘?Û‰,q´)±ˆ\^°’Œý4sŸ¡ûjËòHF­Ü4W"Ùw«/9sÔÖt�¼˜n×HÊŽ´— ßOº 3O‘Ÿø"°ÊAXÖÈè0Ø;¼Ä"±gu,FÜÒƒ®TÆ–aËy¬ìT_IÇÌ8 “*šÀMÜœÔ÷`óèXQ1Rs©œDŒI<„Ä� c›P&klü¹ÞQi´‚ÔÁCnè>–ìÄ R6ó}ÕúYÞŸ©¼²„ì"®iKØBëÍ«„ê¡ÇÉßΩ1?Ò. ÑÄ1 ùÃÊȸ×Or:·¬ºŽI’¼�'íG0AQˆ ÿ ×&þ~š�Œñ)ºÀ\�í£¹™!¥tAkàÿÐüû†Âù�hç†à Ýd±**;HŠ5_$˜/ªW jÅb% !-ø`¿˜ñShocked‰;; Œ&@ÑcJLžízébpUÔµêé¹Úìµ$JdÈž ÌLyvimY´— /�þÁØ#¨o[蘦Vq$9÷ŒaÇÜ+iÐ×€z´Ÿ ÆR’ÍÇR*�"“M*Yø?AIt Am#+²ö¡G>*Š˜-x¿¼A}A…ô â¤ÌsŠ_ ¡B$ÕŒ+Qð«qI:²Ì¤½ÉXÖ’ä€ÕˆZÛ×ö#óÀ¿0%Ï·Û*û½ �Éç™K©Ï»de îÇ•èðæÒì!g¥�P$UXJc† "YÍ\ò efªBŽbÞâOÖßÔHdBfR^¿dÖ²Ù*áþ¬û7tà±ÿˆl8NAE¢¢'`ƒšå¿Ýi¢ˆ‘kœ‚,Óg>ß„íÌÁXØ ËÁbýkÖ˜ÍÌ”VÓLô»±«™8>À”$r›Ùƒ3~—½�¹7v¢[lUÏ­éfšlFâýÇè æ_”�U™…¯ªÅ8>Ua­aK‘­1φÇTìÆèÚÜ4ÈbhPPˆÀ£2‡, dLK'òŒü�2i´2eT°HÌ*c… xž´\3LëBI”õ6ëf¦œ:"ð\phÆ™�C­j+ÓkŒA\�Aô‰bE};†âü§+]÷6!ÂQ’ï36?~Hç`��\±$V%¿k†Rõ÷³¬^ñKb2ow‹ ¬�†Áw+° ¡ZÙ>ˆ®wnÅdA™�ÿ”ÒMÅ 7´(eV®XüFfœI6x¾pÃ$KÑž$jFë¿Œè@"E¬*&b’il�ÌÞ`¨\mR$ôâÕ{µ:ÛÙ²“*ov)µd¥ÊÒŒfêsxŠÌÝãùÏ’£Â.˜¢*Ùx~g¼]7¢„›*º�ºL—ïùKaj¡¡è•F49Á”mí!äþ犖ñµã�wRyË~Þêé3smÝé#?ܾòñwjÕj×½þahÄOJ©ËÔpØz'ÐsÇåXü>¦T¨µ–tX&ѵsJxï_<ÍOª�Ÿ‰ˆ)„A ëYÕ–}<ïú#Šè ©$2†ËÈ36±éï�cÐ�ÿ8—ÀP*)ÌY®9GF?µ™pbãðr×|P ùDuxŸ¢òS"z%é>¬ÔD—8j::Ü„CgŸÉÄh¾Èl9¬h¼°”­¶û;œ(’G{+ï ‡�Ycnñ§¯ÿÁôù‡Œ¦šÇ»+œñ +…¬ ^ÄÇ $ò£��p ™�j5úºë÷pG‡³XÑÌ¿ãK‚im™7ƒÈ¶DÂDLòR´´?ß׋Ó7A Å›ndÅú_î²�Íq§É[W}$%: y}sðÁAæ—3˜“h¡Óc~Þ^êp‰¸œ‡a8「’¿J�u/ƒý­ðW�Â!Óa=Õ t�ñQÄD6¸*Ê4dNÒŽ*&ìÚwÒ>!ò Fvˆeìµdüš%üÔB!RD3¾ß³–1›GÅrã|ý÷NnyI9¥åW®Èê·d|Œ&qrh\�•‰~f¿<ÄsLkÏD.ãÜ(]š¤p6”Úh²á˜Ø|'@R”dR×,NÒjÂÔÙ¸�Ù°0qV¿ö]°—Éâï 3§›„ |íwí°˜*êeÕÓŠHѼÔI¶R­¹jµÕcì~[Ô~cjµûnÈ®�øöЬAòåÇtV %èPTy ¿žƒÿý͉F®/³`Íüð8Šû«�qÃø¨0;¢^A©2¶(Ñ\€cz@”Ýý¶2øvxMâ,¿ x&±„!ENœš§ß“sÅføo«žów! S£î¬¼Á—Œ¡2Šåù†{¡õ¿'Bø±’“—J¾vÌoª[›vtµîýVut?/λþ³ä�'£8g=îoc³aâãˆí_Ä«P ]lE›:ã}A FÚ€ÅÌÈѪzó›Ïa!jŽ«–}ìAX™…™×ìv‰skJÐõýÈv'¾Ýõ•îï¤PÍ�SëY–˜oo G"fïOðû,ñ?ç‡ú�žß�Êj”ºäD{'ú(0°Dãe,Ì‚–ý›•¥)¾­ªQ~Ìà‡œ§�‡`šŸãdÂÿPAYxàÉɧ…4�¨Œº�6‚#7µÒzÿápºmÀd›ãÀXxo“Õ|ÙâĨz¿ÉÛgC<Èü1£Ö o’ò©ñåã Ή�b'…BpžÉQ^m�†IÑ£¡”�\‘2±{?“ËǪ2‚Mão4 Çp\ÏH­dÄ»^&Þ�€•~Ë ƒ>‘y¯û†­è ŸB\‹DG!÷ô¬ˆ f<�Aí¾] ‹«œúªlòH0+˜”�àÏùÅiíÝjÓ`Cq­ê¯½~ÕÓ£Ú™ÎÒØ=q§‰c~ è ”¹.*.0ü]Ðû1ÁÒ|YÜ•7ǵP?Æ$ÄiHÌL*™\¶íYZŠË¤uidî0§/ÿBIˆ:çµ{ùÇ5–î�zØö3˪™Š#_Ð{èÎ0òåÅOø ©OYM,‘Œ=…D6“(T·ìæ5nM»•¥î8<ü3Ýqˆknh…PßrXe#îŽ?‡^Ù7Ð1€�OøvqÝgØú‚�“.}:ôªÈ{žÿ$þ,!qG…—ÂÜP 9Lʈ¬2ˆ>á&ýoMinµ‘ô2¦�"�Sýä^=ºšû?ƒa£xæ$\ÉH°aÁaˆÕ›Á¯P×%ËÍ^f“"ãÃŒ$¢Ö òXEŠ�Ë/êŸ�¬îžéw[ýºU$¸Üy¼.Ö˜¬¬ßL³_äxÒfܾ[mx�+-ÏWZ4n¥`?AybYA�ÈgC']MÄ=2§§ÁžmG­†#“~¶x?2i—¸é‰qÃ,-¡Uc*Y õÆô³fô—'m¨eã¦Ø½°[ÐùVèá¯*Mñå–æÉïŒõž6qÁ°Åàc~€�J툑!Ó§±iÑÆ 9‚ò]bif�a#t4£ì†%RF5ôv�‡ZlH‰|ƒ„‡P$ª§ùLÀËå-"š�ÞÊ% ™kÞÉ„bšë”Ì##Ía.f9ÊË+`ÉÄ�ɤ å@îÃÔS«Ð}tPøç›Ò—,ßÊ}1Ÿ°9c �tÍóVˆ‡Mž�r¤V�ùU講/]³‚Óq±nüRÅ$œòÔï%·¸u½Ëô­’ßÈÏè tØ�ö‡LñcÓ"ˆ&&n°µ¸²_g#žð£TM ™-Eõ{v‰’ƒ“’,+Å�ÐH\åj=UÜrï¨Æ4gRôOÐh‘—�Ù`I4žWÑèY56¾’PÙ›蘾ödk¾<÷§þ³ ,·$<Ýd&„+[ï™%þ v–Às*Høe…ŒXOTÉâ&âèôwÉÒD¯)ػ߯UŽD“ D@©��¼5£9H�§.h]Î-AOTînqÅIY·4Û¸‚Ù8HÃZ,\|âpæVpÉQ±}ΟÍy ÍÏ“Á‚ùÞí%ÖØüò�t`ƒùb¦dg“‘Uísa¡�щ'XƒÆ,FSDݘ٠Oœå�%0` t«àyÕôCÔ5 Ð`J8ßÄŽ%ÌÚú-ó„ìf`¹ÏW÷‘º¡ãáôn"Éu×b•KÄñ™Q’Š¾Cy`?¹ƒëa9ªIæt5‚¡÷æ•[ÕÕè¹'Uõ "†žcázìâ©�÷ÁãÜLw³k](ìúHÁ%ã–.ÃŒUI4xªM}wz Bå�D€´§ p… ŽÐ˜È–žÀèìÎóÏ�«^IÖü±n9¹šõ×­ „§É©ÚøqFM}Co1EÕÆï)¨¡#\DŸ�L“Èöžšæ ‚NñåØ€ïLÐêÁù1$?ÑæC%–Õù­Hø³O¯Æ®DR=ÌÎ@ô�ë@¼ÃÌ„ÙÄQ®�†Ü]Ô A|K&°;BWM…$u)°ÉLdHîžÔÝŠÈɾôÎH EµÁ¥ûÛ(~dµä7­G l~KÁ bA�BúE™(#Š¥Žë™äÅ“­µHÈg�M›_I8�Úßý8(îÁiSJ,)C+`sò�çGc›êlŸdø#Ý”T4E‘i:šæ§²›&¤ ³×«[¡óø×­wSL|Fè$D[p',QÚm¢g.:ŠE6<ÛUïÃâ¹VhXe÷û$]ú½á_\Q8¨,à;¨ª”=(UdqûD1öIÝ%Ùù éÕݵZs+Á¤”1tT{$ gÇ#ÂZýšPŽ$�#¬^‘Ì9]u' �`úi¸çV»à�} Bã¯h„» †©Ï…(˜lom”d±T I¬qÄÿ»¼hø{ö‡K¦Üèªùœ-æ½u©¡˜Bm™GꨳùÏö´mC ݦM[˜)85Z•‡Y£†Œ?ö7uýøqðhaù[·ï÷‡MÂçL7’&´“Gî†!mÂ☙áL´»UZPÔòvaÆø¦°AôÛ†"1&FY¹Ç[^4Y%‰á,‘EPË\¦|ßO•²¯…Ú Í\’ R<’Tz¥.#§Qóùê¹[뽑Œ7¢äÓoz2º¯Ê€è Î7®=\:±££®X‘ynÕ®Bä¨L±PRCer�-}É‘35ÉŠ´äÖÁPá'|Fc–ÙÇi¬�€OÊ.ùÊ!ûûJ}ûdwT¦³ëñÂ#YJ©±Ö‰�Y’–Åœ¿ãžj$®1¸±œ£ÆC™x‹¦¯°[æ ¹pNå%¼uÒ:{âñUç ¨ÏN^û&$ ”Duüg25bª|†õN„»ILé¶Sˉ®8´,>#sMÐû^2i1Ûuá$ÒB?b‰úâbœÓÜÙ]–™€ÑÁ9Omùü½È”“wÝâ§=&ñláþÓžp½H|Ø $Ó8D±t"‡tþRCIh;ùû®”®ËRÝnP¡xÿÉÚÂ6U ›8ƒ6…ó¯~Zæd‘H ®Ì åOdÏZt³µ ß9¹m;³Öó�f¡y&›~ýýÏ€4�ùUˆ+ Ïní¾W:¼ Óc†Ô|>K2*O‹�­÷X%.1údž­¢º„w û>¯UMÀc-=‡ä{B4Bÿ1Ôÿ!¬ÃóZšCÏÝ«vª¡$Œ:И·ùW#OÞkõþºsý¾û_쇞ÿHFà‰˜¸9TLmS@Ánë*X¦”¯>øžô«ñ`ðµïÞaë¼#…¥øHF¬µ ö�£pÊ·�iÎ|Š,¤±F†zu«¡êLÃhÃH¤”m_Á(_++†`ã3‚ë¸ò7¯ÔÅÈ÷fÓýJ$g2×ÊŽÜfϲ½P¿½s•½´"CY¡í–=N‰6TîrÂ!‘¥¡ª¡Ï[.ÙáSd¶Wb�Î…GÞc<ߺ=¼'øÃ[vÒ³­.�Ì*ØùÍtá/I)is¸U?7™ f~h|¶¢g(ß’­ò- ‰;ƒ€¸çWˆ¼§°ßõ¤úÌŽÌâ1ÍU?ëúÄ'�±buXe¾ÓÎoR ]K�‹žn³€ñeûqíõo»üŽ8WEyùö„ã £vÉãÁæ¬Q…‚‚)Á:ÑlÈd4Õ?ÌZ¹�÷±®SºškÐ^Uç#×óžPë 5ö‹‰Ÿœ–hBÐ�–¥XÿËÝ£õ-»� ?^Ö@óΰ°«•Ç.§súƒßÅÅÿÀ”ØÝoý«^RÅ�pôkŒLFR>Œ>éÈʼn±Òýë˜$¹ùÝÐ â\{4¿\®¶Ø¾O—ÀDÉßë³èHòI ”ƒÐúg79ËÕÕ)pMiÞôS:¢„"$ßç¦Ã®Æš{Ó ré 3¦b0`Ïœ �Z„ ¿fäfMK ¶"ù5öeØg³±spz ¡)RH™á™i1,âÿXWÀˆ*ç( “E0ða),jô†‹9°éË¢±XËPÓ� �c€Â瀛¹ û^<ÂH˜ü9*¬’0C¢²ÿꮉ‘°Î i±rv«ÕrcüfyÊë·¿ëhEb9K1b©-Ëx òx±Ó«V3cæ¸s¥Ð5ƒOgm 9–铉{“ºybp29-¡å¼Žª1¢7G˜ªâ/ �ò‡ÇRÉ�Ý� �,"‰ä;UÚùEæÊSt16ÈM¥O ¸a� ÿ7Ô±P!6ò¹€ˆäZ"iÄVèhr\ 4Á$‚yÌpŒ×Â|{ ó©^ׯØýh"añšK¬�›1 S:>Š\é!×*Ðéå ‹ÛJÅ«ÿ€KJÉ -~SÆÍÀÒp $;FQkÜçgÙ%$0´/ éòä­@–añ¡]ždˆme*Â*øž xoØ°ÄDL hX¼˜H MîÜ€ó8oÔ÷TXqöMº€—I¿†¹&_c'÷»çƒbËzŸs*ˆÓ ¹Áÿ£³˜K DSmÃظªZíí(ÅÅåZnÁ÷Ó¬µ}˜Ñx½p ÂmnI{ˆ ÞÜê5\(Љ7W­…B¢gÔҵ͗ÄÌÕDÂánŽá2N¬ÐM�"žÒ)"$úqä6ìÏü¢Ix(¶`¤R QX üU¹Vdí$‰C룀„ Ç@Ÿu†åÃö¿¼[ w�k?H�¹qA~©´9©•9Q4ž`Åó­ÔŠôÎÉõòÒù^[V~ÈËàAK£‡O³+3;©•YµqT±±Ü 2mìQs°æu~†JëìýÈcûÒK»úõÄ€Hdá92ã¹ÿÍ«§jÊHNZ¤á²¶f0ùX;Nrò�ú…²Œ'Qd_PäñÜ4¡£°¢±ÅÜ1ÛñŒ§‰’GÆhŪµÖîìv­sÙ?�¹íê /ý-ö1š×‘üþkqÍø˜Xi­' Ò³D*¶W웥ü­:n5®f‰83ä�Ù† m-…#¹nq1î²4BïÖoïÆT‘ Táßd¯5¼Åë ßã@ZëpV¨‰ïïôØOÐwÕAƒU ËžU¶2ÁHnXȘ~)S§âôÆœÔ;;‹…{j¤wyxß•T‘ÎD*YÇ ”Gv% ¥µ_ÙKvÕåö~ à�æ: d!š˜»YRôžÇÏÁ,`ª�ÛÇNëpiÈ� L|(Àù,ðlC˜�•ÏLî­ª�ñŽ¢ÉŸÿòŸ{·Úí�årw2 úóAŒqßz€<ønœMNžÓ\å"¶êוn#QV¶Z„ÖS¸]«î0òý:/}s@‰ÁZ'LÀî­ß;Hب‹K3ûv=ž…ž©31ÛÂ]þ­«ì«S“ß)¶§×¹-™%|ŠúŽŠLõÔa¬·¦e> äiÅÔ-ÖÉͯėÔ�Ë·÷üF ]ÑïÆpâõô8B1Lá�uõ›H>ÅzæŸM¦O(˜”>¥ HŠ•i]WÖ¬$›OÍóÄÝ‹ úg„/ï« ¬UMŸ" NQ–vGçÝuònnr/lR“×üÛ �8ad/Å« øàÑ4p¿]-TÞ½9¬tóCZþ^j?`N“`KÛ¹�­&üAïÒÍÑýñ­cêö.ò¤�¶¯6@w …„ZúsÔÙPÿX— @{¨ÎÎ1k¶ÅUVêÃßbÊ|Vª.�-4¥§½ô˜N�¸¤+BpÛƒ­}ᵇ=K`å%‰¬"%ú:L +0$žqAòºÀÀ'Èž(‚:þ(VŠ„²(ªúÑ`]÷EG[¾HQÜ‚ûøD÷¼ Ëò.ãAVî ‚›Öú¯iš·Xµ’‹Gª:·”¶z%N–/l Rmòq3ÒÇ0DºëÚ*›ÍQg‚²ÀZfÿ…‰•d"†@ªÒXp¥€íÜGÍ°î:2둱TËÏ?dÁ ®3:Å~Ž~´À[B¶6îã(4 š+M;ïøÞºï½7„ôx985^Û ¥B'Õ¨ôAqªÈS:^ˆô‹WÂë:$–O9‹¶Ã_•N:N™º'»…Cɶ/tßg¥o�i"yé)\_yŸÞ¾¯B ¤ÏR`ús'©²Œœ]3��ðóÏáèU«¯sõ7Ëu¿+êžä×.¯¯¸»«,Ò6L^ú¯Ëi€:®ªQq1A¤j$3€í%�jÝó½fñ×xÃ0Õö•–y¤Qð9ì8eâðwΛ²Š[­†Òè!jP“MQz Ò¯’§ÑõÄ·qœŸyßÍÊ×\ü¾º@¨½kœui]½­Sã¶TEûûvq4qÐÏd¸¥ß_«M0®BóÎÐ Y‘Ö¹MéaÑ)çžÿn¢Î¶î³­û¥6®ŽÛÓ&k¬«v,wR0 ã÷g¾Ñ¯R4 a/‹®ˆõ­LÐÜžÞ¬Óß• °ƒÌ VvŠƒ¡9D¡04«¯u*™“1–ƒ˜²-u­8ä·þ¹Õ™{2‘¾+†-ЀÈÿï †PQ×–j‰�!Ä3¹ PͲR¨Î ³-¯øu×0 ÀWV¶²ŒÆøå.ÂõßýDvXIùL9Ëàñõ Ph/°™¿ƒuœäí KU'x>¿‡±E](BûRÔ´�µæEcÝô:q¦zšÒ:ÑåàÒ@ïAˆ¥Ð‡Z-Ñx6˜ŽBRÄÒ¡·\Š+¯ø‘o4[®j…Ûõ¬ýxe¡t‘ÅÅMI}vfaßpŽÖíLì_£@ @ÀŠÔÆ™&Ê¥¼±§¿¤ÅÜ£¨éaÞ$ÒÔ¯”Ì8KöO3…„ýŽÇ8ê¼dçÏ^+¦0ŒÎ%æ¾ÎclçÇçWÌ‹?Ú6­©)r¼À[‡I(|À¹_.Åzó@÷—ï]Æ$6ÍÈç—øû‰É=ÍúJr^Üæ[ÓCõ °»Æœ �Aû\kábéˆ0÷1Øéq“úÕL’°Ù£ãìYºì àN¢èWóÇ“qì%/§�u;÷4‡¾¼Þÿ¨zéÎoí½Z&›,úæÓª·Q³z&¨Ehr+Ñ6xq"3õ¬:иã]X7OÑûñQëÌáþ‹BÂ$“/žÊÂÙÀÆ åS|O¹cø rª·7o¢�:w*90�ä é½)ÌáUÚb\‹ '¶ z_N&¬ÁßlƒHKê � ��f~×ùCoÍ-· A·ÃÓÐêóƒ0Èèú!@»>€Þk¾É—E¯ø±q4çŒõTÆžš=Œ%våoT@_‘R³oÑp­ÞP�dmsYáoxbÇÐ|sž^±æ‰_Y)ÑíÜ=7¸¦�£8>àfBBŠ)ò¢êÌþo#I¨ÒœUYTÆè³­ÉÑ-Æ[‘‚Ø9ò‰‡’ǵKk¤ÇZ $qx눿Þö”³ À‹Ê0r÷}K~IÞbŒùzû”ññÊÙÿÇõ»ßË9 €îK^
Where? I've tried following the link suggested on the Service Status page and can't see anything that says Live Server monitor
Sorry have now found it,was on the wrong service page
Mine's 223.20kbps Sad why is it so low?
