Where do I get get an installation disk
could someone tell me how i can get an installation disk for my broadband package?
PLUSNET don't seem to reply to their emails ... i wonder why? Sad
Moderators note by John (johnessex) All capitals title made lower case. See the Link:rules
I don't think Plusnet do them anymore - where have you been for the past 5 or so years Wink
craiglay
You don't really need one...
If you were supplied with the free modem, perhaps a Voyager 105, it creates a "dialup" connection in the network connections icon on the control panel. You can download the package from the BT site.
If you have a router, just login using your PlusNet login and password. Note you should use "username@plusdsl.com" i think...
The good thing about PlusNet is that it doesn't change your browser icons, names, install software, etc.. Just a plain connection. Email setup is much different and is probably explained elsewhere..
THANKS DUDE Cheesy
isn't that just GREAT....someone else other than Plusnet replying quicker...psssh
